Slab - Wall (Insulation) - Slab : wall not visible
I have two composite foundation slabs with a wall (insulation) in between. All three elements have status (new construction). The problem is that with Renovation filter set to New Construction (first image) I don't see the insulation wall but only the two slabs while with Renovation filter set to Planned status (second image) I can see all the three elements. Can you explain me how to all three elements with Renovation filter set to New Construction?
Thanks.
2 REPLIES 2
Again, both images uploaded:
- RenovationFilter_NewConstruction
- RenovationFilter_PlannedStatus.
David Maudlin
andrejt:
Take a look at Renovation Filter Options. My guess is that the New Elements are set to Override for the New Construction Filter Settings, while it is set to Show for the Planned status setting.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
