2021-07-05
06:20 AM
2025-02-06
11:14 AM
Aruzhan Hamar
2021-07-05 07:44 AM
n = REQUEST ("ASSOCLP_PARVALUE", expr, name_or_index, type, flags, dim1, dim2, p_values)
n = REQUEST ("ASSOCLP_PARVALUE_WITH_DESCRIPTION", expr, name_or_index, type, flags, dim1, dim2, p_values_and_descriptions)
2021-07-05 08:28 AM
2021-07-05 03:08 PM
2021-07-07 01:04 AM
2021-07-09 07:38 AM
2021-07-09 08:48 AM
2021-07-09 10:33 AM
Vincent wrote:Feel free to contact me. Yes, I was trying to solve many typically problematic areas with my template and library. Some areas of the template still need to be continually developed. I also started on this forum open source GDL project - where I plan to share GDL codes. But currently, I cannot find anyone who is willing to help me to push this development forward as I cannot end up just working on free for the ArchiCAD community. I could - but then Graphisoft needs to start paying me a salary.
@Podolsky I had a quick look at the template you provided, and the surface label is just incredible.. this is the next level of coding! I really need to find time to learn GDL as it is now always what I lack in my search of having a template file and workflow as BIM as possible.
I'll have to spend more time exploring your template as I'm sure it does contain a lot more gems like the surface label. Would you mind if I PM you about a couple of things regarding the label? Also, I'd be more than happy to share with you some of the systems I've put in place on my template to make team's life easier if that can interest you!
2021-07-09 10:57 AM
Podolsky wrote:It seems indeed that people prefer spending money on employee hours and legal fees rather than having a smart and efficient template/workflow... I've myself started this template exercise as I was exasperated of having to clean people shit all the time in order to be able doing decent work. Call it OCD if you want but i'd rather call it working smarter and more efficient. I'm happy to share any progress i've done on my template with you since you kindly shared all that hard work of yours! I'll send you an email or a pm next week!
Vincent wrote:Fill free to contact me. Yes, I was trying to solve many typically problematic areas with my template and library. Some areas of the template still need to be continued developed. I also started on this forum open source GDL project - where I plan to share GDL codes. But currently I cannot find anyone who is willing to help me to push this development forward as I cannot end up just working on free for ArchiCAD community. I could - but then Graphisoft needs to start paying me salary.
@Podolsky I had a quick look to the template you provided, and the surface label is just incredible.. this is next level of coding! I really need to find time to learn GDL as it is now always what I lack in my search of having a template file and workflow as BIM as possible.
I'll have to spend more time exploring your template as I'm sure it does contain a lot more gems like the surface label. Would you mind if I PM you about a couple of things regarding the label? Also I'd be more than happy to share with you some of the systems I've put in place on my template to make team's life easier if that can interest you!
The template I shared initially was commercial development as I tried to sell it (or find investors to the development) in UK. But unfortunately it wasn't successfully - people like to complain more then they understand. So currently everything hanging in the air. I locked access to my GDL scripts and set expire date in September (in September all objects will be locked for editing). But if anyone thinks that this template can be game changing in their workflow - I'm more than happy to help with that - fix errors, add more features, improve / update User Interface and similar.
2022-01-19 12:42 AM
@Vincent G_ - We have had exactly the same problem with the limited parameters available in the property manager preventing us from using an expression to cut the name of a surface to a code in the window/door schedule. Hopefully, Graphisoft make more parameters available in the property manager to open up so many more opportunities for this tool! Please let us know if you find a solution!
