Title Types resetting them selves
We're having a problem at the moment where we insert a custom title type on our drawings, and then the next time we open the file the title type has changed back to the default 'Built In' drawing title.
Our custom titles are still loaded and available in the title type drop down menu...
Any one else had this? Any ideas?
9 Replies 9
Brett Brown
Its a bug confirmed by Graphisoft NZ,so hopefully fixed in the next hotfix
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
Thanks.
Finger's crossed they fix it.
I also turned this one in to Budapest and I got the impression it was a high priority fix.
In my experience, the issue is with drawings in migrated projects, and newly-placed drawings are better behaved. So a workaround is to delete and replace the drawings.
James Murray
We're having the problem in brand new v11 only projects.
Any updates on this? We're also having problems in a file that originated in v11.
It was fixed in the last hotfix. All fine and dandy now.
Sure enough, I don't have the latest update. I'll install that and re-try. Thanks for the reply.
vfrontiers
Ummm... I beg to differ! It's happening for me in the MOST CURRENT update 1114...
Tho.. I must say some in the office are not current... maybe I need to get everyone to 1114?
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
If they're using the same files as you, it would be highly recommended. 😉
Karl
