rjwilden
Title block text error
Any one else having this trouble with there title block numbering.
See image. Detail number is jammed hard left and outside the circle.
This has happened to my template file and I cant find a way to fix it.
"Link"reckons its a bug.If so others should be experiencing it.
Richard
Richard Wilden Design. Ltd
Dunedin, New Zealand.
Imac 27" i9 3.6GHz; 32GB Ram Mac OS 11.3
Archicad V23:V24
David Maudlin
Richard:
In the US ArchiCAD Library 12, there is a Title called "Title with Layout No 12", which looks similar to your title (it would help if you gave the title's name). Under the parameter Show Drawing Number there is a parameter called Text Position X which will move the drawing number. If you do not see this parameter, you can try opening the library part and seeing if it is a hidden parameter. If so, you can unhide it, it may have taken a value other than zero (perhaps from injecting the parameters from another title).
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
