CarlM
Use different image fills in Graphic Overrides depending on 3D-texture alignment
I have set up a GO that I use in elevations to display image fills on wall for example - to show the client what the different materials will look like.
Is there anyway that I can get the 3D-texture alignment parameter and adjust the image fill to orient itself accordingly?
Or is the best approach just to have two identical Surfaces stored as vertical or horisontal (for say a wooden panel) and then create two corresponding image fills?
Thanks!
AC 27 SWE, 64-bit
Windows 10 PRO
HP ZBook Fury 16 G9 Mobile Workstation, i9-12950HX, Nvidia RTX A4500, 64GB ram
No you can not control texture alignment with Graphic Overrides.
All you can do is swap the surfaces/materials.
CarlM
Ok, thanks Barry!
AC 27 SWE, 64-bit
Windows 10 PRO
