2007-06-07 05:28 AM - last edited on 2023-05-26 12:07 AM by Gordana Radonic
2007-06-11 10:01 PM
2007-06-28 09:56 PM
2007-06-29 05:56 PM
this situation for individual layouts by changing the layer to the correct layer in the layout.What do you mean? The layer of what object? Or do you mean the layer combination for that particular layout sheet?
you go to open the next view, you now have to correct the layer as it changed when you set the previous layer.Do you mean "Set the previous layer" in order to draw stuff? Or do you mean you have to re-select the layer combination for the particular layout?
the layer was set in the layout instead of in the plan document.Do you mean the layer
2007-06-29 06:04 PM
2007-06-29 07:20 PM
2007-06-29 09:30 PM
danlawrence wrote:Do
I have noticed that I can correct this situation for individual layouts by changing the layer to the correct layer in the layout.
danlawrence wrote:Yes
It is only happening for a few layouts, so I am assuming that it is happening because the layer was set in the layout instead of in the plan document.
2007-06-29 11:31 PM
danlawrence wrote:Sounds like a simple layer issue, where the layers of your drawings are hiding, is all. There are different attributes for the the modeling environment and the layouting environment. Maybe this will help?
