Window Marker on Elevation
How do you get the window marker to show on the elevation of the building for AC 19? For AC 18 you check the "Label Elements" box and select a label type (see image), but AC 19 does not have the "Label Elements" box anymore.
4 Replies 4
Eduardo Rolon
Read here:
http://archicad-talk.graphisoft.com/viewtopic.php?t=49612&start=0
Labels were upgraded in 19 so you might want to look in the manual and youtube channel so you can adjust your workflows.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Eduardo,
Thanks. I see it. One more question: how do I get the text to be positioned in the middle of the label symbol. I have selected the "In Shape" option but the text is shown outside. See image
Eduardo Rolon
text style -> alignment -> Center
AC29 US/INT -> AC08
another Moderator
Thanks much.
