JessicaBoll08
Window Schedule Merge Issue
I am working on a window schedule for a project.  I have a room that has the same window in multiple locations, when I choose to merge those items the unit size width and height disappear, even on the units that don't have multiples.
Can anyone give me an insight on how to fix this?
Version 25.0.0
Build Number 5010
1 Reply 1
Minh Nguyen
Thank you very much for the question!
From the description and screenshots, it looks similar to defect DEF-5947. In AC25, there is an option for changing Merge behavior. Please find the attached screenshot to see how to find it. If you open the Merge option dialog and click OK, the field will be visible. Could you please give it a try?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
