Window and Door opening line
My windows and doors seem to be acting up. It's not a new development, but I just haven't gotten around to asking this before. Apparently some, or most of my windows (casement mostly) and doors don't show the opening line in elevation properly. It's actually flipped around. For example, instead of showing the door hinge on the right as it's shown in plan, the opening line in elevation shows the hinge on the left.
Has anybody else had this problem? Is there a setting that I need to change, something like a localized setting? Any help will be greatly appreciated.
P.S. If I remember correctly, it started in 8.1, and it's happening in files started in 8.1 AND the ones started in 9.0.
Sergio,
Check out the following:
http://archicad-talk.graphisoft.com/viewtopic.php?p=23484&highlight=opening+line&sid=807c1c828063a2f...
It will take you to a discussion on this forum of this issue.
Peter Devlin
So much for my searching skills - I couldn't find anything. Thanks for your help though.
