Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
archicad dimensioning - problem selecting / snaps
Hello:
Im having a lot of problems using the dimensioning tool.
I just want to measure the distance between center/axis of a wall to the next one, but selecting the center is almost impossible (archicad randomly selects sometimes the center,sometimes the corner, sometimes misclicks the wall, so on....
What snap should i use or tool should i use so this can be done?.
Thanks!.
2 REPLIES 2
You should position the Wall reference line into the center!
Thanks that solve it!.
Took me a while to found that option, for those who don`t know:
-U select the walls, go to Design-Wall extras- Reference line- And select Offset" to the center of core".
