dimension accuracy
Loutro
Hello, I am having trouble controlling the accuracy level of dimensions when using the "elevation dimension" option (as opposed to the "linear dimension" or "cumulative" options).  In Project preferences my length units are set to 1/16" and my "building scale" dimensions are set to 1 /8".
In my project, I have an element to dimension that is 12'-1 1/8".  When I dimension this with the Elevation Dimension marker, it rounds automatically to 12'-1"--however, when I dimension with the linear method, it shows correctly as 12'-1 1/8".  How can I get the elevation dimension method to display the same way?
Thanks,
Loutro
Operating system used: Mac Intel-based Sonoma 14.6.1
Mac OS 14.6.1
Archicad 24 & 26
Jeff Thompson
I think oyu need to change the elevation marker settings in the dimension dialog box...  See the attached image.
Project Manager
Rutledge Maul Architects, PS Inc., Seattle, WA
Windows 11 Pro, HP Pavilion Gaming Desktop 790, Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz 3.19 GHz, 32.0 GB RAM, 64-bit operating system.
Archicad 28 - Graphisoft Forward
Jeff Thompson
Project Manager
Yes, thank you, that was it!
Mac OS 14.6.1
Archicad 24 & 26
Setup info provided by author
