dimensions are not transfering correctly to plotmaker
I have a plan with dimensions set to the nearest inch and published it to plotmaker. the drawing showed up with 16ths and 8ths all over it. is there a way to fix this so it is correct when ploting?
1 REPLY 1
got it, i had to redefine the view with the dimensions in the right place.thanx neway.
