dissapearing fills, text dimensions and lineweights?
Helo.
I am using Archicad for 2 years and I have observed that when I pan or zoom dimensions text, fills and line weights disappears. Is there a way for this not to happen? Because sometimes is confusing...
Thank you!
5 Replies 5
What version?
TomWaltz
Do you mean that they permanently disappear or that they only disappear while you are panning or zooming?
It's completely normal for them to disappear while you are panning. It speeds up your ability to do so. If they disappear from the project, then that's a real problem.
Tom Waltz
No, not permanently, jos when pan and zoom. Is version 11.
I thought so..I am also used to autocad that doesn"t do that and I thought that there is a setting that can make archicad dimensions text lineweights and fills visible permanently.
thenk you.
David Maudlin
andre06:
You can take a look at Work Environment > User Preference Schemes > More Options > Model Display in 2D Navigation, though you might take a performance hit by changing this to Full Model.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David wrote:
andre06:
David
Ooooo...great! Thank you very much for this. It was a good idea to join this forum. There are some quality people around here. Hope that joining this forum I will add some value and help other that have questions.
Thank you again.
