Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
jpg imported into plotmaker
Do you have to keep a jpg in a folder after you import into plotmaker or does the jpg become inserted the lbk file?
2 REPLIES 2
From our experience, once the JPEG is inserted it is still a linked drawing and therefor the LBK looks for the source file. By selecting the drawing under the Drawing Usage tab in the navigator and selecting to Break the Link, the drawing then becomes linked to the LBK and the original JPEG can be removed.
Thanks. I knew you could update it but I didn't know about the unlinking.
Thanks,
Michele
