metric dimensions
howdy
couldn't seem to find a setting to allow me to do the following
we often need to dimension our drawings up in metric.... and by default the dimension string shows... for example... 1,234.. however... i would like it to default to 1234 (NO comma)
is this possible?
using v11 1086 USA full
thanks
yukioMishima
4 Replies 4
yukioMishima wrote:
howdy
is this possible?
thanks
yukioMishima
Try the <Options - Project Preferences - Dimensions> menu; there you can set the unit, decimals, accuracy, etc.
Link
I believe the comma is not actually coming from ArchiCAD, but from your Operating System. On a PC it is accessed via the Control Panel> Regional & Language Options> Customize...> Digit Grouping.
Not sure where it is on a Mac, off the top of my head...
Link.
Rod Jurich
Link wrote:
/......Not sure where it is on a Mac, /....
You may try System Preferences/International.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
I am not quite sure (because i am not currently on a computer with archi) but i belive you can change the units on work enviroment and their presentation. But you must navigate a while on that menu. By this is on a mac.
