radius dimension tool?
i think i know the answer to this, but i am fairly new to Archicad. can i use this tool on a single curve or arc, that has two or more different radius?
4 REPLIES 4
David Larrew
Each radius will need to have an individually assigned radial dimension.
The "Radial Dimension" Tool will not work on one curve element with multiple centers (like and ellipse).
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
__archiben
. . . but will work on a polyline with multiple curves. now if only there was a way to explode an ellipse . . .
b e n _ f r o s t
David Larrew
I guess you could "Magic Wand" the ellipse with a polyline curve - then delete the ellipse.
AC 5.1-25 USA
__archiben
do they do a joint tip-of-the-month?
(thanks . . .)
~/archiben
b e n _ f r o s t
