renovation Status
Okay I may be missing something but I have watched all the videos on the Graphisoft website regarding Renovation in v15 and I have looked through the forum and don't see anyone else having this issue....
I have an existing wall and I want to pop in a door but I also want to show an opening being made on the demolition plan. My question is how do I fix this without popping in an empty opening to show the demolition?
Thanks!
See photo below.
And these are the new openings....
David Maudlin
JennB:
To have a demo plan that shows existing walls with solid lines and dashed lines where the new openings will be, set the Renovation Filter Options for Demolition Plan to:
Existing Elements: Show
Elements to be Demolished: Override
New Elements: Hide
In the Renovation Override Styles > Override Styles for Elements to be Demolished: check Line Type and set to Dashed.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Weird... I swear I had a signature... I don't know why it changed.
Thank you for you help.... I was missing one thing: Setting the Elements to be demolished to Override.
It's always something so simple.
Thanks again.
Jenn
