terrain / slab line type
Hello,
where do I change in 2d view of terrain or slab outlines in the story under?
All the the time there is dash-dot.
Thanks
1 Solution
If I understand you correctly:
Options > Project Preferences > Legacy
Then select the line type you want for 2d contours above and below the Story.
Hope this helps.
Go to post
Hope this helps.
Thank you very much!
