Mats Knutsson
AC27 still crashes when creating gdl objects.
I'm on latest hotfixes and liibrary updates. I can't create object in 27...AC crashes all the time. Is it me, my computer or AC? Does anyone else have crashes? I understand the editor is slow but that's my least problem...
HP ZBook Fury 15,6 G8. 11gen i7-11800H 2.3GHz. 32 GB RAM. Nvidia RTX A3000 1GB. AC22-27 SWE.
3 Replies 3
Sam Karli
What does crashing *exactly* mean?
For me, AC27 frozen endless times because I saved two GDL library parts having the same MainID and the one calling the other. This probably caused an endless recursion, eating all the memory of my computer, bringing it to a nearly responseless state. Loading the same .pln/objects did all the time the same.
Just for example.
GDL/Python/C++ dev
Mats Knutsson
We did that once and never ever again...;) My AC is just crashing..
Does it crash consistently for a particular reason?
i.e. as soon as you open the editor, typing a particular command, as soon as you try to save.
Or does it just crash at random times?
Have you sent the bug report in and then followed up with you local support to see if they can tell you anything?
For compatibility with older versions I script in an older version, so I have not scripted much in 27.
But I have used it a little bit and had no crashes.
