2021-03-20 12:43 PM - last edited on 2021-09-14 09:44 AM by Noemi Balogh
Solved! Go to Solution.
2021-04-13 09:36 AM
poChannel = initaddonscope ("PolyOperations", "", "") preparefunction poChannel, "CreateContainer", "inputContainer", "" preparefunction poChannel, "SetSourceContainer", "inputContainer", "" preparefunction poChannel, "CreateContainer", "resultContainer", "" preparefunction poChannel, "SetDestinationContainer", "resultContainer", "" dict polygon polygon.isClosed = 1 polygon.useEdgeInfo = 0 i = 1 polygon.contour.edges.type = 0 polygon.contour.edges.begPoint.x = 0.0 polygon.contour.edges.begPoint.y = 0.0 i = i + 1 polygon.contour.edges.type = 0 polygon.contour.edges.begPoint.x = 3.0 polygon.contour.edges.begPoint.y = 0.0 i = i + 1 polygon.contour.edges.type = 0 polygon.contour.edges.begPoint.x = 3.0 polygon.contour.edges.begPoint.y = 3.0 i = i + 1 polygon.contour.edges.type = 0 polygon.contour.edges.begPoint.x = 0.0 polygon.contour.edges.begPoint.y = 3.0 i = 1 polygon.holes[1].edges.type = 0 polygon.holes[1].edges.begPoint.x = 1.0 polygon.holes[1].edges.begPoint.y = 1.0 i = i + 1 polygon.holes[1].edges.type = 0 polygon.holes[1].edges.begPoint.x = 1.0 polygon.holes[1].edges.begPoint.y = 2.0 i = i + 1 polygon.holes[1].edges.type = 0 polygon.holes[1].edges.begPoint.x = 2.0 polygon.holes[1].edges.begPoint.y = 2.0 i = i + 1 polygon.holes[1].edges.type = 0 polygon.holes[1].edges.begPoint.x = 2.0 polygon.holes[1].edges.begPoint.y = 1.0 preparefunction poChannel, "StoreDictPolygon", "polygon", polygon iPen = 1 gosub "drawPolyOpPolygon" dict polyline polyline.isClosed = 0 polyline.useEdgeInfo = 0 i = 1 polyline.contour.edges.type = 0 polyline.contour.edges.begPoint.x = 0.0 polyline.contour.edges.begPoint.y = -1.0 i = i + 1 polyline.contour.edges.type = 0 polyline.contour.edges.begPoint.x = 2.5 polyline.contour.edges.begPoint.y = 2.0 i = i + 1 polyline.contour.edges.type = 0 polyline.contour.edges.begPoint.x = 4.0 polyline.contour.edges.begPoint.y = 1.0 i = i + 1 polyline.contour.edges.type = 0 polyline.contour.edges.begPoint.x = 6.0 polyline.contour.edges.begPoint.y = 4.0 iPen = 3 dict polygon : polygon = polyline gosub "drawPolyOpPolygon" preparefunction poChannel, "StoreDictPolyline", "polyline", polyline dim resultIDs[] nResult = CALLFUNCTION (poChannel, "ClipPolyline", "polyline polygon", resultIDs) add2 0, 0.01 gosub "drawResultPlines" del 1 closeaddonscope poChannel end "drawResultPlines": for iResult = 1 to nResult dict polygon nVertices = callfunction(poChannel, "GetDestinationDictPolyline", resultIDs[iResult], polygon) iPen = iPen + 1 gosub "drawPolyOpPolygon" next iResult return "drawPolyOpPolygon": ! conversion to status-coded polygon dim outflat[] ! declare returned array polygon.hasClosingPoint = 0 ! always given without repeating the first point call "ProfileConverter" parameters bProfileToPolyOp = 0, bPolyOpDict = 1, PolyOpPolygon = polygon, returned_parameters nOut, outflat ! put results for i = 1 to nOut ! without closing point k = (i - 1) * 3 put outflat[k + 1], ! x outflat[k + 2], ! y outflat[k + 3] + 1 ! status next i ! draw polygon pen iPen poly2_b NSP / 3, 1 + 2, iPen, 0, get(NSP) return
2021-04-06 09:37 AM
2021-04-06 01:42 PM
2021-04-06 01:57 PM
2021-04-08 10:32 PM
2021-04-13 09:36 AM
2021-04-13 05:39 PM
2021-04-13 07:17 PM
