GDL
SOLVED!
Custom MVO checkbox title won't show up
silvermat
Hello,
I've created custom MVO with one checkbox. It shows only category title but not the checkbox until I disable it and enable again.
Any idea why it happen?
Windows 11
Archicad 28 POL
1 ACCEPTED SOLUTION
Solution
There is one easy fix: Double the last line and replace the "0" with a "1".
Since there is no actual command for a checkbox (it's just a subtype set with the "7") the UI_INFIELD command is very broad in it's definition. Just remembert this: You need to explicitly mention every state the UI thingy can take. Even it is just a checkbox with literally two states.
4 REPLIES 4
Is it the size of the checkbox?
Is it overlapping the text?
In the interface preview, hit the 'Check' button to see if there are any overlaps.
There is my code. I don't see any overlaps, but it's my first project with interface so I can miss something.
! set basic variables
_yCurr		= 5
_dy		= 25		! generic line spacing
_totalWidth	= 600		! fixed value to match the exisiting panels
_totalHeight	= 4* _dy	! calculate the height from line spacing
_stDialogTitle	= `Janowicz Architekci`
! set title and height for the custom MVO panel
ui_dialog _stDialogTitle, _totalWidth, _totalHeight
! content
ui_style 0, 1
ui_outfield `Widoczność elementów`, 0, _yCurr, 150, 15
ui_style 0, 0
ui_infield{4} "JA_show_c_z_w", 0, _dy, 200, 19,
			7, "",
			0,
			0, 0, 0,
			0, 0,
			"", "Pokaż wyposażenie sanitarne", 0
Solution
It's works! Thank You
