Customising an object: Insert Autotext to automaticlly use ID as text
Hi All,
I'm trying to create a custom object based on Archicad's 'Signal Thermastat 21' Object.
Here's what I'd like to do:
1. I'd like the 'text' to automatically be the 'ID'. Is there a way to use auto text in this situation?
See pic attached.
2. I'd like to change the circle to a rectangle that I can resize with hotspots and numeric input.
Thanks in advanced!
10 Replies 10
DGSketcher
Legend
Peter wrote:
About keynoting lines: the name of the line type could be used as data.
Peter, I have opened a new thread, perhaps you could expand on your suggestion. Thanks.
https://archicad-talk.graphisoft.com/viewtopic.php?p=319607#p319607
