2021-02-04
03:07 AM
2021-09-14
01:26 PM
Noemi Balogh
!ROUND HOTSPOT 0,0,0 MATERIAL Material_color !PLATE ROTX 90 CYLIND .5", W/2 !BRACKET ADDZ .5" CYLIND 2", .625" ADDZ 2" CYLIND 4", 3/8" !CONNECTION ADDZ 4" ROTZ 270 ELBOW 1.5", 90, 3/8" ADDZ 1.5" ADDX 1.5" ROTY 90 CYLIND 1", .5”
2021-02-04 03:19 AM
PRISM_ 7, 0.100, 0.011, 0.0, 11+64, 0, 0.0, 900, 0, 180, 4011+64, -0.011, 0.0, 11+64, 0, 0.0, 900, 0, 180, 4011+64, 0.011, 0.0, -1 ROTz 90 ADD 0, -0.098,0.100 REVOLVE 7, 169, 1*0+2*0+4*0+16*0+32*0+64*0, 0.011, 0.098, 1, 0, 0.098, 900, 0, 180, 4011+64, -0.011, 0.098, 1, 0, 0.098, 900, 0, 180, 4011+64, 0.011, 0.098, 1
2021-02-04 10:42 AM
Barry: You can 'Group' them and they will mergeHow does this work with GROUP commands?
2021-02-04 11:31 AM
W=0.1 group "object" !ROUND HOTSPOT 0,0,0 MATERIAL 20 !PLATE ROTX 90 CYLIND .5", W/2 !BRACKET ADDZ .5" CYLIND 2", .625" ADDZ 2" CYLIND 4", 3/8" !CONNECTION ADDZ 4" ROTZ 270 ELBOW 1.5", 90, 3/8" ADDZ 1.5" ADDX 1.5" ROTY 90 CYLIND 1", 0.5" endgroup placegroup "object"
2021-02-04 12:47 PM
A. SmithThank you, but in AC 22 on MAC OS with this code the line is still visible,
2021-02-04 01:41 PM
TUBE 4, 11, 1+2+16+32,
0.01, -0.01, 900,
-0.01, -0.01, 0,
-0.01, +0.01, 0,
0.01, +0.01, 0,
-1, 0, 0, 0,
0, 0, 0, 0,
0, 0, 0, 0,
0.135, 0, 0, 0,
0.135+0.0575*sin(15), 0.06-0.06*cos(15), 0, 0,
0.135+0.0575*sin(30), 0.06-0.06*cos(30), 0, 0,
0.135+0.0575*sin(45), 0.06-0.06*cos(45), 0, 0,
0.135+0.0575*sin(60), 0.06-0.06*cos(60), 0, 0,
0.135+0.0575*sin(75), 0.06-0.06*cos(75), 0, 0,
0.135+0.0575, 0.06, 0, 0,
2021-02-04 02:25 PM
tap_obj=addgroup ("object", "object")
placegroup tap_obj
2021-02-04 03:21 PM
A. SmithNo, Addgroup I checked, it does not hide the lines.
2021-02-04 03:55 PM
200: !ROUND HOTSPOT 0,0,0 MATERIAL Material_color !PLATE ROTX 90 CYLIND .5", W/2 !BRACKET ADDZ .5" CYLIND 2", .625" !SPOUT ADDZ 2" ROTZ 270 PRISM_ 7, 4", 3/8", 0.0, 11+64, 0, 0.0, 900, 0, 180, 4011+64, -3/8", 0.0, 11+64, 0, 0.0, 900, 0, 180, 4011+64, 3/8", 0.0, -1 ROTz 90 ADD 0, -1.5",4" REVOLVE 7, 90, 1*0+2*0+4*0+16*0+32*1+64*0, 3/8", 1.5", 1, 0, 1.5", 900, 0, 180, 4011+64, -3/8", 1.5", 1, 0, 1.5", 900, 0, 180, 4011+64, 3/8", 1.5", 1 ADDZ 1.5" ROTX 90 CYLIND 1", .5" END
2021-02-05 01:52 AM
group "object"
!ROUND
HOTSPOT 0,0,0
MATERIAL 20
!PLATE
ROTX 90
CYLIND .5", W/2
!BRACKET
CYLIND 2", .625"
endgroup
placegroup "object" !!!comment out this line
result = ADDGROUP ("object","object")
!placegroup result !!!uncomment this line
Joachim wrote:Tubes are good, you just have to work out the point coordinates for the path.
Another way to get it work is TUBE, which I always use for this kind of tubed objects.
