rudl
Easy gdl mesh
Easy mesh:
! No more VERT EDGE PGON ! (because its a bit of a pain)
just a vertex array
and a face array with vert indices
Face direction should be automatic with the order of vertices, Edges are automatic
Needs more testing, may add some more features.
! Geometry stored in vert and pgon arrays only Example: Pyramid
! Important order of vertices in Pgon determine Normal / Face direction
! --- SETUP VARIABLES ---
dim points_s[][3]	!points start
dim edges_pi[][2]	!edges point index
dim faces_pi[][]	!faces point index
dim ppf[]			!points per face
! --- POPULATE ---
points_s[1][1] = -1 : points_s[1][2] = -1 : points_s[1][3] = 0	! base
points_s[2][1] =  1 : points_s[2][2] = -1 : points_s[2][3] = 0
points_s[3][1] =  1 : points_s[3][2] =  1 : points_s[3][3] = 0
points_s[4][1] = -1 : points_s[4][2] =  1 : points_s[4][3] = 0
points_s[5][1] =  0 : points_s[5][2] =  0 : points_s[5][3] = 2  	! apex
ppf[1] = 4 : faces_pi[1][1] = 1 : faces_pi[1][2] = 4 : faces_pi[1][3] = 3 : faces_pi[1][4] = 2 	! base (quad)
ppf[2] = 3 : faces_pi[2][1] = 1 : faces_pi[2][2] = 2 : faces_pi[2][3] = 5
ppf[3] = 3 : faces_pi[3][1] = 2 : faces_pi[3][2] = 3 : faces_pi[3][3] = 5
ppf[4] = 3 : faces_pi[4][1] = 3 : faces_pi[4][2] = 4 : faces_pi[4][3] = 5
ppf[5] = 3 : faces_pi[5][1] = 4 : faces_pi[5][2] = 1 : faces_pi[5][3] = 5
nPoints = 5 		! this should be known does not make sense to calc! optional with VARDIM1
nFaces = 5 		! this should be known does not make sense to calc! optional with VARDIM1
! DO THE MAGIC THING:
! --- Point index for edges --- edges_pi[][2] for use in EDGE
x=0	! the counter is important!
FOR i=1 TO nFaces
	FOR j=1 TO ppf[i]
		x = x+1
		IF j < ppf[i] THEN
			edges_pi[x][1]=faces_pi[i][j]
			edges_pi[x][2]=faces_pi[i][j+1]
		ELSE
			edges_pi[x][1]=faces_pi[i][j] !connect last point of face with first
			edges_pi[x][2]=faces_pi[i][1]
		ENDIF
	NEXT j
NEXT i
lengthedge = VARDIM1 (edges_pi) ! total edges with duplicates should be nEDGE
! --- Create edge index --- edges[] for use in PGON
! There is some kind of "sorting" through to make the double edge indices negative
! could be optimised for larger meshes though
DIM edges[]
negcount = 0
FOR i = 1 TO lengthedge
	u = edges_pi[i][1]
	v = edges_pi[i][2]
	edges[i]=i-negcount
		FOR j = 1 To i
			IF edges_pi[j][1]=v AND edges_pi[j][2] = u THEN
				edges[i]= edges[j]*(-1)
				negcount = negcount+1
			ENDIF
		NEXT J
NEXT i
! BUILDING THE MESH:
!PUT EVERYTHING TOGETHER
BASE
FOR i = 1 TO nPoints
	VERT points_s[i][1],points_s[i][2],points_s[i][3]
NEXT i
	IF edges[i]>=1 THEN
		EDGE edges_pi[i][1], edges_pi[i][2],-1,-1,0
	ENDIF
NEXT i
PUT edges
FOR i = 1 TO nFaces
	PGON ppf[i],0,0,GET(ppf[i])
NEXT i
BODY -1
! DEBUG:
!PRINT edges_pi
!PRINT edges
16 Replies 16
rudl
That is definitely on my todo list.
Main focus is still making it easier to script meshes within gdl.
rudl
Parametric torus and bended beams.
Torus example:
theta = 360/u
FOR i = 2 TO u
	vec_temp[1]=po_s[i-1]
	GOSUB "V_ArotX":
	po_s[i] = vec_temp[3]
NEXT i
FOR i =1 TO u
	po_s[i][2]=	po_s[i][2]+rv
NEXT i
theta = 360/v
FOR i = 1 TO v-1
	FOR j = 1 TO u
		vec_temp[1]=po_s[(i-1)*u+j]
		GOSUB "V_ArotZ":
		po_s[i*u+j] = vec_temp[3]
	NEXT j
NEXT i
c =0
FOR i = 1 TO v
	FOR j = 1 TO u
		IF i = v THEN
		IF j = u THEN
		c = c +1
		f_pi[c][1]=(i-1)*u+j
		f_pi[c][2]= j
		f_pi[c][3]=(i-2)*u+j+1
		c = c +1
		f_pi[c][1]= j
		f_pi[c][2]= 1
		ELSE
		c = c +1
		f_pi[c][2]= j
		f_pi[c][3]=(i-1)*u+j+1
		c = c +1
		f_pi[c][1]= j
		f_pi[c][2]= j+1
		f_pi[c][3]= (i-1)*u+j+1
	 	ENDIF
		ELSE
		IF j = u THEN
		c = c +1
		f_pi[c][2]=(i)*u+j
		c = c +1
		f_pi[c][1]=(i)*u+j
		f_pi[c][2]=(i-1)*u+j+1
		ELSE
		c = c +1
		f_pi[c][2]=(i)*u+j
		c = c +1
		f_pi[c][1]= (i)*u+j
		f_pi[c][2]= (i)*u+j+1
	 	ENDIF
		ENDIF
	NEXT j
NEXT i
rudl
*) Monkey read from text-file
*) Arbitary rotation around an axis rodriques transformation
*) Display Helper Axes
rudl
UVs
rudl
Subdivided Icosahedron  / Geodesic
! ICOSPHERE
IF examples = "icosphere" THEN
!BASE ICOSAHEDRON
	phi = (1.0 + SQR(5.0)) / 2 !1.6180339887
	nPoints = 12 : nFaces = 20 : nEdges = 60
	!POINTS
	po_s[1][1] = -1 : po_s[1][2] = phi : po_s[1][3] = 0
	po_s[2][1] = 1 : po_s[2][2] = phi : po_s[2][3] = 0
	po_s[3][1] = -1 : po_s[3][2] = -phi : po_s[3][3] = 0
	po_s[4][1] = 1 : po_s[4][2] = -phi : po_s[4][3] = 0
	po_s[5][1] = 0 : po_s[5][2] = -1 : po_s[5][3] = phi
	po_s[6][1] = 0 : po_s[6][2] = 1 : po_s[6][3] = phi
	po_s[7][1] = 0 : po_s[7][2] = -1 : po_s[7][3] = -phi
	po_s[8][1] = 0 : po_s[8][2] = 1 : po_s[8][3] = -phi
	po_s[9][1] = phi : po_s[9][2] = 0 : po_s[9][3] = -1
	po_s[10][1] = phi : po_s[10][2] = 0 : po_s[10][3] = 1
	po_s[11][1] = -phi : po_s[11][2] = 0 : po_s[11][3] = -1
	po_s[12][1] = -phi : po_s[12][2] = 0 : po_s[12][3] = 1
	!FACES
	f_pi[1][1] = 1 : f_pi[1][2] = 12 : f_pi[1][3]= 6
	f_pi[2][1] = 1 : f_pi[2][2] = 6 : f_pi[2][3]= 2
	f_pi[3][1] = 1 : f_pi[3][2] = 2 : f_pi[3][3]= 8
	f_pi[4][1] = 1 : f_pi[4][2] = 8 : f_pi[4][3]= 11
	f_pi[5][1] = 1 : f_pi[5][2] = 11 : f_pi[5][3]= 12
	f_pi[6][1] = 2 : f_pi[6][2] = 6 : f_pi[6][3]= 10
	f_pi[7][1] = 6 : f_pi[7][2] = 12 : f_pi[7][3]= 5
	f_pi[8][1] = 12 : f_pi[8][2] = 11 : f_pi[8][3]= 3
	f_pi[9][1] = 11 : f_pi[9][2] = 8 : f_pi[9][3]= 7
	f_pi[10][1] = 8 : f_pi[10][2] = 2 : f_pi[10][3]= 9
	f_pi[11][1] = 4 : f_pi[11][2] = 10 : f_pi[11][3]= 5
	f_pi[12][1] = 4 : f_pi[12][2] = 5 : f_pi[12][3]= 3
	f_pi[13][1] = 4 : f_pi[13][2] = 3 : f_pi[13][3]= 7
	f_pi[14][1] = 4 : f_pi[14][2] = 7 : f_pi[14][3]= 9
	f_pi[15][1] = 4 : f_pi[15][2] = 9 : f_pi[15][3]= 10
	f_pi[16][1] = 5 : f_pi[16][2] = 10 : f_pi[16][3]= 6
	f_pi[17][1] = 3 : f_pi[17][2] = 5 : f_pi[17][3]= 12
	f_pi[18][1] = 7 : f_pi[18][2] = 3 : f_pi[18][3]= 11
	f_pi[19][1] = 9 : f_pi[19][2] = 7 : f_pi[19][3]= 8
	f_pi[20][1] = 10 : f_pi[20][2] = 9 : f_pi[20][3]= 2
!SUBDIVISION
FOR s = 1 TO subdivide
DIM f_pi_temp[][]		!faces point index
DIM edge_su[][2] 		!temp edges for subdivision
DIM po_midkeys[][]		!mid keys of points po_midkeys[][1] = count | po_midkeys[][x+1] midpoint indices
DIM mid_indices[] 		!mid indices
DIM mid_indices_clear[] !mid indices clear
FOR i = 1 to nFaces
	mid_indices = mid_indices_clear
	edge_su[1][1] = f_pi[i][1] : edge_su[1][2] = f_pi[i][2]
	edge_su[2][1] = f_pi[i][2] : edge_su[2][2] = f_pi[i][3]
	edge_su[3][1] = f_pi[i][3] : edge_su[3][2] = f_pi[i][1]
	FOR j = 1 TO 3
		midpoint = 0
		!Check if midpoint exists
		IF po_midkeys[edge_su[j][1]] [1] # 0 AND po_midkeys[edge_su[j][2]] [1] # 0 THEN
			FOR l = 1 TO  po_midkeys[edge_su[j][1]] [1]
				FOR m = 1 TO  po_midkeys[edge_su[j][2]] [1]
					IF 	po_midkeys[edge_su[j][1]][l+1] = po_midkeys[edge_su[j][2]][m+1] THEN
						mid_indices[j] = po_midkeys[edge_su[j][2]][m+1]
						midpoint = 1
					ENDIF
				NEXT m
			NEXT l
		ENDIF
		IF midpoint = 0 THEN
			nPoints = nPoints + 1
			mid_indices[j] = nPoints
			po_s[nPoints][1] = (po_s[edge_su[j][1]][1]+po_s[edge_su[j][2]][1])/2
			po_s[nPoints][2] = (po_s[edge_su[j][1]][2]+po_s[edge_su[j][2]][2])/2
			po_s[nPoints][3] = (po_s[edge_su[j][1]][3]+po_s[edge_su[j][2]][3])/2
			countm = po_midkeys[edge_su[j][1]] [1]
			countm = countm +1
			po_midkeys[edge_su[j][1]] [1] = countm
			po_midkeys[edge_su[j][1]] [countm +1] = nPoints
			countm = po_midkeys[edge_su[j][2]] [1]
			countm = countm +1
			po_midkeys[edge_su[j][2]] [1] = countm
			po_midkeys[edge_su[j][2]] [countm +1] = nPoints
		ENDIF
	NEXT j
	f_pi_temp[(i-1)*4+1][1] = f_pi[i][1]
	f_pi_temp[(i-1)*4+1][2] = mid_indices[1]
	f_pi_temp[(i-1)*4+1][3] = mid_indices[3]
	f_pi_temp[(i-1)*4+2][1] = f_pi[i][2]
	f_pi_temp[(i-1)*4+2][2] = mid_indices[2]
	f_pi_temp[(i-1)*4+2][3] = mid_indices[1]
	f_pi_temp[(i-1)*4+3][1] = f_pi[i][3]
	f_pi_temp[(i-1)*4+3][2] = mid_indices[3]
	f_pi_temp[(i-1)*4+3][3] = mid_indices[2]
   	f_pi_temp[(i-1)*4+4][1] = mid_indices[1]
	f_pi_temp[(i-1)*4+4][2] = mid_indices[2]
	f_pi_temp[(i-1)*4+4][3] = mid_indices[3]
NEXT i
f_pi = f_pi_temp
GOSUB "metrics_calc"
next s
	vec_temp[1] = po_s[i]
	GOSUB "V_Aunit":
	po_s[i] = vec_out[1]
	po_s[i][1] = po_s[i][1]*p_ru
	po_s[i][2] = po_s[i][2]*p_ru
	po_s[i][3] = po_s[i][3]*p_ru
NEXT i
GOSUB "BB_calc"
ENDIF
rudl
Loop subdivision, having some fun with chatgpt
rudl
With some help from chatgpt:
