GDL
SOLVED!
Fetch data from Polygon Count add on ?
MF BIM
Hello everybody 🙂
Simple question, is there way to get data from the Polygon Count addon ?
Let's say I have a libpart that has too many triangles, could I somehow use that addon to check the count and reduce the resol ? Otherwise, is there a way to calculate that count ?
https://mfbim.fr | https://youtube.com/@mfbim | My GDL course on Udemy, try it !
AC24 FRA 7600 - AC26 FRA 4027 | MacBook M1 Pro
1 ACCEPTED SOLUTION
Solution
There is no way to get it from GDL and iterate the model, 3D generation is a one-step process.
If you are using resol (or toler or radius) in your code then you can calculate or estimate the polygon count.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
4 REPLIES 4
Erik Bjornhage
Not sure if I understood your questions - but here goes:
"...could I somehow use that addon to check the count..."
Yes, this is exactly what PolyCount does
"...and reduce the resol?"
No, not reduce the resolution/triangle count using the PolyCount add-on - this you would have to do separately, either by editing the object directly or creating a new object.
"Otherwise, is there a way to calculate that count?"
Not sure what it is you want to calculate?
Erik Bjornhage : SwedishChef, ETTELVA Arkitekter, Gothenburg, Sweden
Architect : Digital Development : Graphisoft Cert. BIM-Manager
ETTELVA Arkitekter : Eriks LinkedIn
DELL Precision 5570; i7-12700H; 64 GB; RTX A2000 [8GB] : AC12 - future
Hello @Erik Bjornhage ,
Thanks for replying. What I meant is when creating a GDL object, is there a way to know or calculate to polygon count in the object at any given moment. That's why I was wondering if somehow there was a way to get the data from that addon directly into my GDL objects.
Solution
Péter Baksa
Thanks
Then I understand, but can't add any more to the discussion unfortunately. I still need to take the time to get into GDL 😞
Peter seems to have a good answer for you below.
