File IO in properties script
Properties script of a GDL object tries to write some data into a file.
Activating the script from menu (Listak | Elemlista | ...) works well. However by calling ACAPI_Element_GetComponents from an add-on properties script fails to write into the file. (It creates the file.)
Is there any work around for this problem?
Using: ArchiCAD 8.1R2 HUN (2284) on w2k sp4
Thanks,
Csaba Nagy
3 Replies 3
Hi Csaba,
Someone with more experience may know the answer, but I wonder if this thread is related:
http://archicad-talk.graphisoft.com/viewtopic.php?t=4716
Perhaps the API call does not force a full execution of the script...?
If this is the case then full execution of property scripts upon ACAPI_Element_GetComponents is #1 on my API wishlist.
- at least until I get around to rewriting my property scripts in c
I found a work around. Executing an SQL Query runs the script correctly.
(APIAny_ExecuteSQLQueryID "select components from ...")
Csaba
