GDL
Font Type Not Working Through Subtype Parameter
Jarrod Phillips
Hi All,
I am having an issue where I have created a font type parameter in an object subtype, however the font type doesn't want to work in the child object.
See script below:
Parameter in subtype = fta_font_type (string)
2D script
define style "fontStyle1" fta_font_type, fta_font_size, 5, fta_iFont_effects    !LABEL FONT STYLE
style "fontStyle1"
Interface Script
ui_infield{2} 'fta_font_type', _uiXRight, _uiY, _columnWidth, _fillHeight ui_tooltip "Font Type"
_uiY = _uiY + (_fillHeight + _buttonGap1)
Cannot for the life of me workout why it's not working, any assistance would be greatly appreciated.
Regards,
Jarrod
BIM Manager | Graduate of Architecture
Fulton Trotter Architects - Sydney, Australia
Archicad 15 - 27
3 ACCEPTED SOLUTIONS
That won't give you a list of available fonts.
You will have to type the font name exactly in that field.
You can either create your own VALUES list for the 'fta_font_type' variable, where you can list specific font names.
Or this (in the parameter script) will search your operating system and give you a list of all of the installed fonts.
DIM fontNames[]
n = REQUEST("FONTNAMES_LIST", "", fontNames)
VALUES "fta_font_type" fontNames, CUSTOM
Hi Jarrod
We can change the variable name that represents your text style with the parameter shown on the picture (default by the Label subtype).
Device name Asus v16
Processor Intel(R) Core(TM) 5 210H 2.20 GHz
Installed RAM 16.0 GB
Good catch.
I forgot about these fixed name optional parameters.
It seems you can use AC_TextFont_1 up to AC_TextFont_8, should you need different fonts for different reasons all in the one object.
5 REPLIES 5
DIM fontNames[]
Hi Jarrod
Good catch.
Jarrod Phillips
All excellent solutions, thank you!
Archicad 15 - 27
Showing the font list can be done without parameter script: https://gdl.graphisoft.com/tips-and-tricks/font-names-list-handling-in-ui-script
The parameters which have a font list come from libparts under subtype "Library Master". These are executed when the library is loaded, and their parameters' value ranges are inherited by all other library parts. https://gdl.graphisoft.com/gdl-basics/parameter-logic
PƩter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
