GDL can read hardware id?
Hello.
I am making very simple objects for use specifics, and i want to know, how i can get the hardware id? for purpose of licence simple, only with gdl.
1 Solution
Peter Baksa
Hi andomar,
n = REQUEST ("Configuration_number", "", stConfigurationNumber)
Returns the configuration number (as string expression) assigned to the current ARCHICAD license in case of soft license or hardware key. Returns empty string in case of Edu, Trial or Demo licenses. Each configuration number is unique and does not change.
To access the hardware ID you would need to write an add-on.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
Go to post
6 Replies 6
Look under the request options in the gdl pdf.
I believe you can get it from the program info request for the serial number
Thanks for your help.
That way the GDL gets the information from archicad, but it's not what I'm looking for.
I want it to report the hardware id (pc), which is found in the device specifications.
Or any way to get the host name, but direct into the gdl object? (for example in power shell of windows, this: C:\>hostname )
Like this example:
Peter Baksa
Hi andomar,
Péter Baksa
Thanks a lot
vanxis
Hi
where to find GDL Development Kit 25?  The GDL Development Kit seems to have stopped at version 23
Archicad user and Developer
Peter Baksa
Please contact API support about this.
Péter Baksa
