GDL
SOLVED!
How do I rotate objects acording to view rotation?
Odd Goderstad
I have some symbols that I want to rotate according to view rotation? I was thinking that a simple Rot2 command should do it, but how do I get the view rotation? Example please, I have been away from GDL writing for so many years...
🙂 Odd Goderstad
GS Norge
Oslo, Norway
Always the latest version ArchiCAD mostly on Windows
twitter: @OddGoderstad
1 ACCEPTED SOLUTION
Solution
David Maudlin
Odd Goderstad:
From the GDL Reference Guide:
n = REQUEST ("view_rotangle", "", angleViewRotation)
Returns the rotation angle of the current view. Expression returns 0 and contains dummy return values (emtpy string or 0) if used in parameter script, causing additional warning
You can then use the returned value to rotate all or part of the object.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
2 REPLIES 2
Solution
David Maudlin
Odd Goderstad:
David
Odd Goderstad
Thanks a lot, I will try
🙂 Odd Goderstad
GS Norge
Oslo, Norway
