How to make a schedule for parameter arrays in GDL?
Hello everyone,
I have some arrays of plates inside a GDL such as XY, ID, size, and color
Question: Is there any way to make a 2D schedule to calculate some parameter array like as quantity of plates, size, ID... also inside that GDL (button to display)
Regards
Peter Baksa
No, GDL objects can't open an schedule window or define a scheme if that's what you need.
You can calculate parameters based on others in the parameter script. Library part parameters can be added to a schedule scheme, and a scheme can be exported and imported to be used in many pln files.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
Thank Peter,
Sadly.. because I have a dynamic array with many attributes, so Schedule Scheme just can import normal parameter, cannot import array parameters.
