2021-07-29
03:11 PM
2021-09-14
08:55 AM
Noemi Balogh
Solved! Go to Solution.
2021-07-30 02:49 AM
GDL wrote:
I am creating a Master GDL Object that calls in various Macro Objects to place them in the final assembly.
2021-07-29 04:24 PM
GDL wrote:Master GDL Object is executing only when you are loading the library. So it's good for setting global variables (GLOB_USER) and fills and surfaces.
Hi GDL Experts,
I am creating a Master GDL Object that calls in various Macro Objects to place them in the final assembly. Each Macro Object has various Parameters.
In the Master GDL Object, should every Parameter of the Macro Objects be listed out? For instance if each Macro Object has 15 parameters, then the master could easily have a lot of Parameters.
Many thanks in advance!
2021-07-30 02:49 AM
2021-07-30 02:01 PM
