PARAM-O What is the Point Inputs for?
Hello guys. What is the goal of the point inputs in paramo? I mean, the Point variable and the Vector variable. What is the use cases of them, and do you guys have any example of it in use? The only use for a vector a saw is use it to move another shape, but I can do this with a simple move node. The point otherhand, I dont see any use for it, i definitely dont know what is it intended to.
The "Line Points" Node has a "Begin Point" and an "End Point" Input.
The Output of the "Point" Node can be connected to either.
