runxel
Poly2 flips the line
When using a symbol line for poly2 and its brethren it will flip the line direction at the rounded parts. With the native polyline this of course does not happen.
What did I miss?
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
1 Solution
Podolsky
Ace
Try to change direction how to describe nodes (clockwise or anticlockwise). That might help.
Go to post
Podolsky
Ace
runxel
You were right.
I had the the coordinates "PUT" in the wrong order. After I have reversed it to be CCW everything looks fine again.
Somehow the obvious things are always to be overlooked at first glance
Thanks!
