scottjm
Mentor
Prevent Eyedropper / Syringe from changing a specific Parameter
I have a label, that has a parameter that I don't want to be modified when I use the eyedropper / syringe.  Is this possible?  I still want this parameter to be editable by the user though, so I can't force a default a value through VALUES or PARAMETERS.
I'm wondering if it's possible to get the previous value of a parameter when it gets modified by the Eyedropper/Syringe and then push the old value back into the parameter.
Thanks,
Scott
13 Replies 13
Peter Baksa
The syringe on the plan transfers various element settings, and treats the selected library part with all its parameters as one setting.
I agree it would be helpful to be able to control the library part and its parameters separately in the transfer exclusions.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
runxel
Yeah, maybe we could have the possibility for a more granular way of syringing/injecting parameters in the future.
I know, it's not easy to implement. In the end you always have to think of all the scenarios and balance pros and cons.
E.g. there are 2 possible ways to handle this:
• The programmer chooses which parameters are never to be picked for one object (great, because they probably know best; but not so good if you have a malicious programmer :P)
• The user can set this as part of the element transfer settings (which is not easy due to the custom naming of parameters)
• Or actually both.
On a related side note: It would be great to have the ability to pick the settings from objects which belong to a system, too (where they are a sub-element like in stairs, CWs, railings, etc.) and inject them later! Especially with railings this would save some nerves 🙂
scottjm
Mentor
Hi @Peter Baksa ,
What can we do to get this request onto the roadmap?
My feeling is that if the programmer sets a parameter as Unique, it should be not be overridden by the syringe tool.  The way it appears to currently function is not the expected behaviour.
Thanks,
Scott
Peter Baksa
You can enter a wish or tell support about this problem.
Péter Baksa
