2025-12-16 06:51 PM
I am creating an object that will be a parametric car ramp using a tube command as a base of geometry. The geometry is then cut to parametric outline in plan to fit the needed geometry.
And I found out that tube command (1st or 2nd) is buggy as hell with alignment of the geometry parts.
It is not visible from the outside, but doing a section reveals the "secret". Easy to check with the railing tool with the profile of the slab 3m wide with 2 layers one finish - 5cm and base - 20 cm.
The left is a non cut one the right is using the cut to fit the outline.
Plan i rotated 90 deg from what is seen in 3d
Here goes the section of the non cut one:
The outside is aligned...but not what happens inside.
But when it is cut it becomes even "funnier":
Any fix of this command is on the "go"?
It is very usable in many cases.
For finishing the tool I have on the workshop I will probably need to do a series of bolean operations which will slow down the model...or I will give the advice to use single, non composite slab...which sounds no good.
Piotr
2026-01-22 11:36 PM
For now I partially solved the issue (because there are still funny irregularities but much smaller) with every single composite to be slightly thicker and a bool subtraction of the offseted dummy element below - so the top & bottom surface is almost the same way triangularized.
2026-04-13 03:12 AM
that's amazing!
