Narska
Wall end lines on custom window
How can I remove the wall end lines of a custom window object?
I use the fragment2 command so that the symbol is independent from the size of the actual window. Ganging command in window properties does not eliminate it.
Tomasz Mlynarski
New York based Architect
1 Reply 1
Add a WALLHOLE2 command in 2D script
see this topic: https://archicad-talk.graphisoft.com/viewtopic.php?f=49&t=70194
Creator of Cadswift's parametric GDL libraries
Creator of Infinite Openings and Component Catalogues
Push the envelope & watch it bend
website: https://cadswift.com.au/
YouTube: https://www.youtube.com/user/CADSwift/playlists
