2020-07-2801:17 AM - last edited on 2022-09-2610:48 PM by Daniel Kassai
2020-07-2801:17 AM
How can I remove the wall end lines of a custom window object?
I use the fragment2 command so that the symbol is independent from the size of the actual window. Ganging command in window properties does not eliminate it.
Creator of Cadswift's parametric GDL libraries
Creator of Infinite Openings and Component Catalogues
Push the envelope & watch it bend
website: https://cadswift.com.au/
YouTube: https://www.youtube.com/user/CADSwift/playlists
