Mats_Knutsson
Mentor
Zone accessory object tweak...can't find the zone edge length...?
Spoiler
I figured I'd test tweaking the wall acessory object to add a fill along the generated wall surface objects to indicate what kind of material that is being used. However I don't know the correct parameter to use.
/Mats
AC 25 SWE Full
There is an array parameter with the coords of the points, it is funny ... the heritage lays deep in the Imperial Units: the normal point has the third coord of a value of "one inch" and the ending point, or ending point of a hole 3rd coord value is "two inches", the accesories do not support curved edges, all is faceted on the level of the addon.
Piotr
