GDL
if GLOB_CONTEXT > 40 & GLOB_CONTEXT < 50 in not Deprecated mode?
If wiling to get additional cutting body for door/window for creating opening (with opening tool, not seo) in eg. wall that is an additional insulation in renovation I was trying to use GLOB_SEO_MODE... but it does nothing, but if GLOB_CONTEXT > 40 & GLOB_CONTEXT < 50 does the trick... so why those commands went "Deprecated" while there is no new one...and  the old one is still used in 28?
refs:
Deprecated Global Variables | GRAPHISOFT GDL Center
https://gdl.graphisoft.com/gdl-style-guide/general-scripting-issues/#GDLExecutionContext_section
10 REPLIES 10
A yes... sliding windows too.
Easy to check if it works is to draw a crossing wall with higher junction order in place where window is and then do "Create openings from selection" having the window selected
I have to investigate it more - it seems to be working in 28...but I had problems with it in 26...so maybe in 26 it was not implemented.
Arghh....Monaco GDL editor is still horrible...opened a window and then selected macro ...it took ages to kick in with the code
