parametrically change a projectors frustum
HI
I created a simple shape that represents the frustum of a projector. I have to change this (zoom angle and projection distance) to place the projector to a specific place in a room to fill the designed screen. I can do this in sketchup, but I am transitioning to Archicad. How can I add these parameters to modify the mesh/morph? I am really a beginner here, so go easy please I have attached my first try.
Lingwisyer
Guru
I have not viewed the object due to version limitations.
Did you code your shape or is it from a Save as object...?
distance = screen_size / ( 2 * tan(lens_angle / 2) )
You can use the above to calculate the distance for a given projected size and lens angle.
Ling.
