General discussions
Posts about job ads, news about competitions, events, learning resources, research, etc.
Archicad 26 SPA
Victor Leon
Hello everyone, when will Archicad 26 SPA be available?
7 REPLIES 7
Probably best to contact you local Archicad distributor.
I feel your anguish - I'm still waiting for the AUS version which is about 2 weeks away.
Versions 6.5 to 26
GOBA
Hi, it's here, even if it says Archicad 25 SPA:
https://Graphisoft.com/es/resources-and-support/downloads?localization=SPA&type=FULL&version=25
ArchiCAD user since November 2109
AC24, Windows 10
Seems like the 'download' link on the Spanish site doesn't do anything.
And if you go through the menu on the right (the 3 bars) and go to support and downloads, you will end up at the link you provided and it shows version 25.
Someone just hasn't updated the web sit properly.
But on the link you provided you can just change it to 26 in the URL or choose 26 in the version option.
Versions 6.5 to 26
It´s an update which asks you for a "normal" AC 26 installation.Captura de pantalla 2022-08-22 103123.png
Sorry, I don't actually read Spanish.
Yes that was a link just for the update 3010.
The initial installation can be found here ... https://graphisoft.com/downloads/archicad/install/AC26/SPA
Versions 6.5 to 26
I thought that link was wrong too.
It shows 25 when you hover over it but does seem to download 26 OK.
Versions 6.5 to 26
Thank you, Barry!
