Ajaytonpe
Archicad AC25 Update 5005 Issues
Archicad Team,
We are facing major problem post this update...
1. there are major graphics bugs (all curve lines , staircases are not showing properly)
2. Image maps are showing pixelated.
3. same thing is going in BIMx. (BIMx file runs very sluggish, sections shows odd geometry)
Its a serious issue in our workflow. we are using BIMcloud advance. so all machines and all projects got updated.
Kindly give us solutions asap.
AJAY T
AJAY_T
1 Solution
Ajaytonpe
Hi Sorry for late reply.... Issue is resolved 🙂
it was a issue of Far from origin... we had imported survey DWG file and it was far from origin.
  1. we saved the file locally.
  2. we changed EASTING / NORTHING to 0
  3. Then we moved the model with the survey point on the project origin.
  4. Re shared the file
Thanks!
AJAY_T
Go to post
8 Replies 8
Minh Nguyen
Dear Ajay,
Thank you very much for the question and I am very sorry for the issue!
You mentioned that you are using BIMcloud. What if you save a local copy of the project as PLA format, will the same issue happen? Furthermore, I would like to make sure that the project is not suffered from Far from Origin issue.
Please let me know how it goes!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Ajaytonpe
Hi Minh,
there is no issue in local file... its on BIMCLOUD file.
also we are not having issue for far from origin.
AJAY_T
Minh Nguyen
Dear Ajay,
If that's the case, then the issue is not with the Archicad update, but there must be something else with your model in BIMcloud. I strongly suggest contacting your local support with the information you had here, as they will be able to offer direct support at your convenient time.
Thank you for your understanding!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Ajaytonpe
Thanks!
AJAY_T
dushyant
Facing the same issue with a bimcloud/teamwork project.  When an element is selected, the snap points are not aligned with the geometry. Attaching screenshot.
Minh Nguyen
Thank you very much for the question!
Same as above, I'm wondering if you save a local copy of the project as PLA format, will the same issue happen? Furthermore, I would like to make sure that the project is not suffered from Far from Origin issue.
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
dushyant
There is no issue in the local PLA/PLN file. The issue arises only when it is shared on teamwork.
ryejuan
i have also encountered issues with the saved model view options. on my system its being displayed correctly but when i send changes to other users end up it turns out to be "missing" not sure if this issue has been resolved or looked into.
WINDOWS 11 PRO
