General discussions
Posts about job ads, news about competitions, events, learning resources, research, etc.
Archicad "Learn"
mattmgut
Hi.  I am trying to get to the Learn site on the Graphisoft website and I get an error message - image attached.  Is that corner of that feature still available?  Or is that now under Learning but the links are still available?
Matthew Guthrie
RHiZO Architecture
MacBook Pro M2 Max, 32GB
macOS 15.2 Sequoia (24C101)
AC 28
Either clear the cookies in your browser cache, try a new browser you have not used before or try your browser in 'private' mode.
There has been an issue with cookies on that website.
Thank you both.  Using a different browser did the trick.  I appreciate the quick responses!
Matthew
Matthew Guthrie
RHiZO Architecture
AC 28
What Barry said.  And, we assume you are using this URL:  https://learn.graphisoft.com
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
