insideru
Disable Dialog Box Panel Opening non-animation on macOS
So the help says: Use Scroll Effects for Dialog Box Panel Opening (Windows Only): By default, to prevent crowding of dialogs when opening new panels, previously opened panels will close automatically, and the dialog box will move upwards on the screen. If you check this box it means that dialog box panels will “roll open” (at the speed you set with the slider) instead of “snapping open,” which is the effect you get if you uncheck the box.
i'm on macOS and this setting is grayed out, yet the speed somehow is still taken in consideration. When i open or close a panel it just stays there for a second. It's been bugging me for years and i can't take it anymore. I'm sure we can disable this ... right?
ARCHICAD 28 INT
macOS Sequoia
0 Replies 0
