mthd
When ArchiCAD was uncomplicated !
ArchiCAD 1.0
No Graphic Overrides in this version 😆 !
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
23 Replies 23
rakurs
Yeah, far from ideal. I wish it would be more intuitive. If only it said "various" or "property varies in selection" or something along those lines, and allow you to unify that same property, whether it is purely geometric (wall height, door width...), constructional (junction order...) or something visibly unrelated (custom property)... Even in Windows, if you select multiple files and look at their properties, you can clearly see what they have in common and what is a variable between them.
Additionally, this "Edit selection set..." dialog does not show all the data (properties) of objects, even if they are really common. No way to see wall heights, junction order...
ArchiCAD 28 | INT - Cro | Forward | WIN 10 / 11
jl_lt
Ace
Yeah, that was it. Thanks Torben!   Not so slow now that i see it again, but still
torben_wadlinger
Thanks, Barry. You're right. To be honest, I can't remember most of the shortcuts but the position of my fingers and the corresponding function.
