ā2025-07-24 11:01 AM - edited ā2025-07-24 11:03 AM
ArchiCAD 1.0
No Graphic Overrides in this version š !
ā2025-07-29 04:50 PM
Yeah, far from ideal. I wish it would be more intuitive. If only it said "various" or "property varies in selection" or something along those lines, and allow you to unify that same property, whether it is purely geometric (wall height, door width...), constructional (junction order...) or something visibly unrelated (custom property)... Even in Windows, if you select multiple files and look at their properties, you can clearly see what they have in common and what is a variable between them.
Additionally, this "Edit selection set..." dialog does not show all the data (properties) of objects, even if they are really common. No way to see wall heights, junction order...
ā2025-07-30 01:32 AM
Yeah, that was it. Thanks Torben! Not so slow now that i see it again, but still
ā2025-07-30 04:59 PM
Thanks, Barry. You're right. To be honest, I can't remember most of the shortcuts but the position of my fingers and the corresponding function.
