Archicad 29 Migration Guide release!
Archicad 29 Migration Guide: your companion for a smooth upgrade
Upgrading to a new Archicad version is exciting, but when you’re in the middle of real project deadlines, it can also raise a lot of practical questions. What changed? Will my template behave the same way? Do I need to adjust anything before continuing?
To make the transition clearer, safer, and a lot more predictable, we created the Archicad 29 Migration Guide, a structured, friendly resource that helps you know exactly what to check when moving your projects from Archicad 28.
How it works
Archicad 29 introduces updates across libraries, workflows, and information management. Some of these changes can impact ongoing projects, others simply make your template better if you choose to adopt them. That’s why the guide is divided into two parts:
Size=36x36 (1).svg
Updates that require checking
These items can affect how migrated projects look or behave.
We highlight everything you should review to avoid errors or inconsistencies.
 Size=36x36.svg
Optional Template improvements
These updates won’t cause issues if left unchanged, they’re enhancements you can integrate when you’re ready. Perfect for refining office standards or teams wanting cleaner workflows.
What’s inside the guide
Explore how Archicad 29 features impact your migration workflow through an interactive clickable guide. Each topic has its own detail page with a consistent, easy-to-read structure:
  • About the topic
  • What's the benefit
  • Migration impact & Our recommendation
  • Action steps & workflows (for more complex updates)
Localized versions coming soon
We know how important it is to work in your own language.
Localized editions, ITA, HUN, BRA, SPA, FRA, and JPN, are planned to be released soon.
Start exploring
We hope the Archicad 29 Migration Guide makes your upgrade smoother and more enjoyable. Start by reviewing the required checks, then explore the optional improvements to get the most out of your template in Archicad 29. Download the guide and start migrating!
DOWNLOAD THE MIGRATION GUIDE
Share:
