3 weeks ago - last edited 3 weeks ago
Dear Customers,
The on-premises BIMcloud release planned for this October, will be the final version supported on macOS. A last maintenance update will follow in spring 2027; after that, future on-premises BIMcloud releases will no longer support macOS.
We know that changes to the platform your team relies on take careful planning. That’s why we’re sharing this update early, so you have time to review your options and prepare with confidence.
Current Mac hardware uses Apple silicon processors. On-premises BIMcloud currently relies on Rosetta 2 technology to run on this architecture, and that technology is scheduled to be phased out in 2027. We do not plan to develop a native Apple silicon version of on-premises BIMcloud for macOS. As a result, we are unable to provide a reliable, maintainable macOS platform for future on-premises BIMcloud releases.
This change affects customers running on-premises BIMcloud on Mac hardware, including customers using BIMcloud Basic on macOS.
It does not affect:
Your existing Mac-based BIMcloud installation may continue to operate as long as its current hardware, macOS version, and wider IT environment remain compatible. However, after the final maintenance update in spring 2027:
If you run on-premises BIMcloud on a Mac, we recommend beginning your transition planning now. Depending on your organization’s needs, you can:
Migrate to BIMcloud SaaS: BIMcloud SaaS is a reliable and secure alternative for teams that prefer a fully managed solution. Operated by Graphisoft, it provides a fully managed collaboration environment so your team can focus on projects rather than maintaining hardware and software infrastructure. It helps reduce the day-to-day IT effort associated with supporting an on-premises environment and can be a practical choice for organizations seeking stable collaboration while reducing infrastructure responsibilities.
Continue using on-premises BIMcloud by moving it to a Windows-based environment.
Please contact your local Graphisoft representative to discuss the migration path most suitable for your environment.
We remain committed to supporting you throughout this transition and helping you choose the path that best fits your organisation's needs.
Sincerely,
Graphisoft Customer Support
