2024-09-13 06:55 AM - last edited on 2024-09-13 07:22 AM by Barry Kelly
Has anyone noticed the resolution of some of the AC28 library parts for some objects in 3D has something going on with it? I loaded the 27 library and also pasted from AC27. AC28 is doing something to them.
See attached image of what I have found so far...
Solved! Go to Solution.
2024-09-13 07:27 AM
Check your Model View Options.
You probably have 'Simplified' or 'Schematic' set for your 3D object presentation.
2024-09-13 07:27 AM
2024-09-13 07:59 AM
thanks! It was the MVO. The objects that had higher resolution were set to full. Some of the objects though are set to rather low resolution by default it appears
