Perhaps KeBenz doesn't need it this time, but this is a good opportunity to point out the SEO stair hole tip...
You should use SEO to cut holes when you want to control the material of the hole separate from the main polygon. Set up the operator slab with the material you want, then subtract from the main slab with 'Inherit attributes of Operator.'
